1999 Mercury Villager Front end shakes
24,000 MILES • 6 CYL • FWD • AUTOMATIC
STEVEGO
This is a mystery. Front shakes bad at 50-60 mph. Back end a little shake. We have had done: alignment, 4 new tires/balanced, then rotated tires, new CV joints , new motor mounts, new rear brake shoes, wheel cylinders, and drums, new rotors, new left lower ball joint. Same vibration in the van. Any help with this would be greatly appreciated! Our mechanic is stumped as are we.
Jun 18, 2010 at 11:03 AM
CARADIODOC
  • 34,391 POSTS
Hi Stevego. Welcome to the forum. Where just the outer cv joints replaced or the entire half shafts with the inner joints? Does the vibration go away when you let off the gas? Is this seen and felt in the steering wheel or just in the seat?
caradiodoc
Jun 18, 2010 at 11:54 AM
