Four wheel drive does not activate and no lights
161,000 MILES • 5.0L • V8
DURIEUX
When using selector 4 wheel drive switch nothing happens no indicator lights illuminate no clicking sound nothing. it says the transfer case is a maxi under the hood but it’s black. so how do you check to see if it’s good or what else could be wrong?
Oct 19, 2019 at 5:23 AM
You just swap it with another one in the fuse box. However, let's check to see if there are codes in the system which can help point us in the correct direction. This could just be a failed switch or something greater. However, if there are codes we will have a better idea. Thanks
Oct 21, 2019 at 7:08 AM
