Hi all. I'm back with another problem ><. Grand Marquis 94 135k miles. Recently i fixed my low egr flow problem. I removed the air intake, cleaned the the ports including the ones for the egr.The car was running good with no engine light.
Next day i decided to change the egr valve as a precaution (dummy me) and installed a new one. I also changed my spark plugs. When i started the car it felt different right away. I can fell the engine hesitate a bit, which it wasn't happening before.
I decided to put everything back to normal, so i put back my old spark plugs and egr valve. That didn't solve the problem unfortunally. I didn't replace the spark plug cables(not sure if that will solve the problem). I did bought the same spark plugs, brand new but still didn't solve it. I also noticed a humming noise that is coming from the transmission area when you turn the key switch on without starting the engine(not sure if is normal), there is a wire harness that connects on the driver side on the transmission. When i unplug it the humming sound stops. Anyway back to my original problem.
Now i'm getting scanner code 172 : Heated Exhaust Gas Oxygen (HEGO) sensor- voltage signal indicates "lean" (bank #1). I just noticed that there is another HEGO sensor (i just only seen one) and it hasn't been replaced. Could it be bad? I did replace the other one. Any ideas or suggestions? Please help!!!!
I just lerned that if the car is running fine ...DON't mess with it, LOL
Mar 27, 2006 at 9:45 AM
