Sorry, but we do not respond directly through e-mail.
You question is not real clear and you didn't post code numbers as you should have but I expect you have PO171 and PO174. This is a common combination on Fords and is usually caused by a severe vacuum leak. They are notorious for sucking holes through the rubber connectors for the large vacuum supplies like the PCV and brake booster. Listen for a hissing noise when idling and try to follow it to it's source.
SPONSORED LINKS
Wednesday, September 8th, 2010 AT 6:03 PM
