1997 Ford Thunderbird Rear Klunking
JOHNNYMC51
I have a 1997 Ford T-Bird 128,000 miles. While driving I hear a klunking sound from the rear of the car. It happens at different times. I can get the car to do it while slowing down to about 30 mph and then accerating it starts the klunking sound then stops. I have also heard the sound while driving on the highway going about 65. I notice the noise while going around a slight curve in the road. Can you help. I don't want a tire to come off the car!
Nov 8, 2006 at 2:50 AM
BRUCE HUNT
  • 3,754 POSTS
I would check lug nuts. Then I would check out any torsion bars for snugness. After that I would examine the shocks and remeber they may seem tight with the car weight on them but once the car is in motion the bounce of the car can show the looseness. Raise the read of the from the frame and not the axle. Check things out.
Nov 8, 2006 at 3:45 AM
Suggested Repair
Check the lug nuts, torsion bar snugness, and shocks. Raise the rear from the frame, not the axle, so any looseness that appears only in motion can be found.
Conversation Summary
The owner of a 1997 Ford Thunderbird with 128,000 miles hears a rear klunking noise at various times, including after slowing to about 30 mph and accelerating, at highway speed, and on slight curves, and is concerned a tire could come off. The expert recommends checking the lug nuts, torsion bar tightness, and shocks, noting that shocks may seem tight under the car's weight but show looseness once the car is moving. The rear should be raised from the frame rather than the axle for inspection.
