fuel pump?????????????????????
FORD WINDSTAR
DRAGONWITCH
i tried to listen for the sound of my fuel pump like you suggested...(lay on ground w/ ear to tank) and i can't hear anything, but i also cannot get all the way under to put my ear directly to the tank. so i tried removing my back seat to listen, no noise. i also tried unscrewing gas cap and listening from there, still no noise. i don't know if i'm just missing it or not. is there a way i can just disconnect a fuel line somewhere and try to start the car and see if there is gas coming from the line? my thinking is that if there's no fuel then obviously there is no working fuel pump!!!!! i can't afford to take it to a shop to have them test it and from the instructions in one manual there a several different testers i need to test it that way....i can't afford to buy those either. i also haven't got the funds to just keep throwing parts at it hoping that i will eventually replace the right one. please help!!!!!!!!!!!!!!!!!!!
Jun 24, 2006 at 12:04 PM
TAURUSWHEEL
  • 718 POSTS
What car is this???
Jun 25, 2006 at 2:37 PM
OTTO
Here's something that has worked for me a number of times. Turn the key on, then reach under and bang the bottom of the tank with a good-sized rock. The shock will often start up a pump that has started to go intermittent.
Good Luck
Jun 26, 2006 at 5:30 AM
TAURUSWHEEL
  • 718 POSTS
I actually did that myself once with a rubber mallet, got me home without a tow,, check the inertia switch make sure it isn't tripped, also if you know what your doing, you can apply 12 volts to the fuel pump wire off the inertia switch and listen for the pump to come on.
Jun 26, 2006 at 11:00 AM
