Ford Windstar steering question
FORD WINDSTAR
SHIELDS29680
I have a 99 ford windstar with 90K miles. Anytime I am turning the car around or turning into or out of a parking spot or turning into a road either left or right, the steering squeaks. While I am driving along, it is fine. This just happens when I am at a complete stop. Power steering fluid is full. Any suggestions?
Dec 18, 2006 at 9:34 PM
BRUCE HUNT
  • 3,754 POSTS
Squeeks or shrieks? I am wondering when you had a belt replaced last on the power steering pump. Check the belt for any cracking, if you find cracking on the under side, replace it. It the belt is new check the tension of the belt. Slippage causes the noise.
Dec 19, 2006 at 1:00 AM
SHIELDS29680
Its not a squealing. It squeaks. Not the belt. Its when I turn the steering wheel.
Dec 19, 2006 at 1:24 AM
BOOTDOG
  • 665 POSTS
are you bottoming out the steering wheel when you turn? if so it will squeal. by doing that your putting a lot of stress on the ps system. or does it sqeal the whole time while you turn?
Dec 19, 2006 at 4:51 AM
SHIELDS29680
It is the whole time I am turning it.
Dec 19, 2006 at 6:26 AM
BOOTDOG
  • 665 POSTS
does the noise sound like it's comming from under the hood or inside the car?
Dec 20, 2006 at 7:41 AM
