2001 Ford Windstar Pulls Left
ROGO41
Our 2001 Ford Windstar pulls to the left. The van has about 120,000 miles on it with 3 month old tires.
We have replaced the front struts, and tie-rods. We had an alignment and rotated and balanced all 4 tires.
However, it pulls to the left severely when the wheel is let go while driving. We had one mechanic move the left front wheel to the right front and he said it then pulled right. We took it to the tire place and they again rotated all the tires and now it pulls left again.
Is this a radial pull (due to bad tires) or something more?
Nov 9, 2006 at 1:43 PM
BOOTDOG
  • 665 POSTS
yes by what u said it is a radial pull. you probably got a bad batch of tires. i did alignments for years and a radial pull is a very common problem. don't worry, the tires won't blow up or anything, it's more annoying than anything else.
Nov 10, 2006 at 4:32 AM
ROGO41
Thanks for the info. We had the 2 front tires replaced yesterday, now it pulls to the right, which is at least safer than to the left.
Nov 11, 2006 at 1:50 AM
Suggested Repair
Treat this as a radial tire pull from a bad tire or batch. Have the tire shop replace the defective tires, preferably under warranty, and recheck the pull after replacement.
Conversation Summary
A 2001 Ford Windstar with newer tires pulls left despite new front struts, tie rods, alignment, rotation, and balancing. Swapping the front tires reversed the pull, which the expert identified as a common radial pull from a bad tire batch rather than a safety blowout risk. After the two front tires were replaced, the van pulled right instead.
