1999 Ford Windstar Front Caliper Won't Retract Fix
GAMEOVER865
on my ford windstar 1999 3.8 LX i tried to replace the front brake pads when i tried to push the calipers one goes in and the other one comes out so for example when i push the top calipar the bottom one come out is there anyway to prevent that from heppening
Oct 9, 2007 at 2:05 AM
BMRFIXIT
  • 19,053 POSTS
[quote:f15408a02c="gameover865"]on my ford windstar 1999 3.8 LX i tried to replace the front brake pads when i tried to push the calipers one goes in and the other one comes out so for example when i push the top calipar the bottom one come out is there anyway to prevent that from heppening[/quote:f15408a02c]
You can use the old brake pad and a c clamp
Push the two cylinders together
Hope you get what I mean
Good luck
Oct 9, 2007 at 12:29 PM
GAMEOVER865
[quote:c455b42389="BMRFIXIT"][quote:c455b42389="gameover865"]on my ford windstar 1999 3.8 LX i tried to replace the front brake pads when i tried to push the calipers one goes in and the other one comes out so for example when i push the top calipar the bottom one come out is there anyway to prevent that from heppening[/quote:c455b42389]
Good luck[/quote:c455b42389]
I tried doing that but it wont go in
Oct 10, 2007 at 1:58 AM
BMRFIXIT
  • 19,053 POSTS
[quote:63b952ef2b="gameover865"][quote:63b952ef2b="BMRFIXIT"][quote:63b952ef2b="gameover865"]on my ford windstar 1999 3.8 LX i tried to replace the front brake pads when i tried to push the calipers one goes in and the other one comes out so for example when i push the top calipar the bottom one come out is there anyway to prevent that from heppening[/quote:63b952ef2b]
Good luck[/quote:63b952ef2b]
I tried doing that but it wont go in[/quote:63b952ef2b]
Caliper off make sure hose not kinked place an old pad in front the caliper pistons
Using a C clamp
Turn the c clamp handle pushing in the pistons
Or u can push in one side and hold it in using a Vise Grip Pliers
and push in the other one
Oct 10, 2007 at 12:04 PM
GAMEOVER865
[quote:a3566342da="BMRFIXIT"][quote:a3566342da="gameover865"][quote:a3566342da="BMRFIXIT"][quote:a3566342da="gameover865"]on my ford windstar 1999 3.8 LX i tried to replace the front brake pads when i tried to push the calipers one goes in and the other one comes out so for example when i push the top calipar the bottom one come out is there anyway to prevent that from heppening[/quote:a3566342da]
Good luck[/quote:a3566342da]
I tried doing that but it wont go in[/quote:a3566342da]
Using a C clamp
and push in the other one[/quote:a3566342da]
it wont go in is there something that will let the air out
Oct 11, 2007 at 1:35 AM
BMRFIXIT
  • 19,053 POSTS
[quote:f25c1ec88f="gameover865"][quote:f25c1ec88f="BMRFIXIT"][quote:f25c1ec88f="gameover865"][quote:f25c1ec88f="BMRFIXIT"][quote:f25c1ec88f="gameover865"]on my ford windstar 1999 3.8 LX i tried to replace the front brake pads when i tried to push the calipers one goes in and the other one comes out so for example when i push the top calipar the bottom one come out is there anyway to prevent that from heppening[/quote:f25c1ec88f]
Good luck[/quote:f25c1ec88f]
I tried doing that but it wont go in[/quote:f25c1ec88f]
Using a C clamp
and push in the other one[/quote:f25c1ec88f]
it wont go in is there something that will let the air out[/quote:f25c1ec88f]
frozen caliper change it
Oct 11, 2007 at 5:30 AM
Suggested Repair
Compress both caliper pistons together with an old pad and a C-clamp, with the hose unkinked. If one piston still pushes the other out, hold the retracted piston with locking pliers and compress the other. If they still will not retract, replace the frozen caliper.
Conversation Summary
On a 1999 Ford Windstar, the owner could not retract the dual front caliper pistons because pushing one caused the other to extend. An old pad and C-clamp, and holding one piston while compressing the other, did not work. The expert concluded the caliper is frozen and should be replaced.
