1998 Ford Windstar Brake Hesitation
DAVID SUMMERS
I am having a problem with the front brakes on a 1998 Ford Windstar,v6,3.0. It has a slight hesitation in the brake peddle just as it about to come to a complete stop. I have changed the rotors and put new pads on, and bled the lines. What else could it be.
Jun 13, 2007 at 1:51 PM
SERVICE WRITER
  • 9,123 POSTS
Mot exactly sure what you mean by hesitation. You should spray doen the rear brakes, gring off any lip on the drum, and adjust the shoes out when you do a front brake job. That may be part of your problem.
Jun 14, 2007 at 12:46 AM
Suggested Repair
Service the rear drum brakes: spray and clean them, grind off any drum lip, and adjust the shoes outward. Incomplete rear adjustment after a front brake job may cause the pedal hesitation near a stop.
Conversation Summary
The owner of a 1998 Ford Windstar reports slight brake-pedal hesitation just before a complete stop. The front rotors and pads were replaced and the lines were bled. The expert says the rear drums should be cleaned, any lip ground off, and the shoes adjusted as part of a front brake job.
