Electrical problem
1998 Ford Windstar 6 cyl Automatic
I have a issue with #7 brake fuse blowing as soon as you hit the brake pedal. I disconnected and cleaned the pressure switch connector as I have read that later windstars had the pressure switch fill with brake fluid and create a short. I also replaced the brake light switch at the pedal. as a result of this I cannot get the vehicle out of gear as this runs on the same circuit. I looked at the stop lamp bulbs,they appear to be ok, I am thinking it may be the shift interlock solenoid but, cannot find any info on this or where it may be located. any ideas what may be causing this?
thank you
thank you
Oct 1, 2010 at 11:41 AM
