Changing Front Brake on Ford Windstar
FORD WINDSTAR
GAMEOVER865
on my ford windstar 1999 3.8 LX i tried to replace the front brake pads when i tried to push the calipers one goes in and the other one comes out so for example when i push the top calipar the bottom one come out is there anyway to prevent that from heppening
Oct 9, 2007 at 2:05 AM
BMRFIXIT
  • 19,053 POSTS
[quote:f15408a02c="gameover865"]on my ford windstar 1999 3.8 LX i tried to replace the front brake pads when i tried to push the calipers one goes in and the other one comes out so for example when i push the top calipar the bottom one come out is there anyway to prevent that from heppening[/quote:f15408a02c]
You can use the old brake pad and a c clamp
Push the two cylinders together
Hope you get what I mean
Good luck
Oct 9, 2007 at 12:29 PM
GAMEOVER865
[quote:c455b42389="BMRFIXIT"][quote:c455b42389="gameover865"]on my ford windstar 1999 3.8 LX i tried to replace the front brake pads when i tried to push the calipers one goes in and the other one comes out so for example when i push the top calipar the bottom one come out is there anyway to prevent that from heppening[/quote:c455b42389]
Good luck[/quote:c455b42389]
I tried doing that but it wont go in
Oct 10, 2007 at 1:58 AM
BMRFIXIT
  • 19,053 POSTS
[quote:63b952ef2b="gameover865"][quote:63b952ef2b="BMRFIXIT"][quote:63b952ef2b="gameover865"]on my ford windstar 1999 3.8 LX i tried to replace the front brake pads when i tried to push the calipers one goes in and the other one comes out so for example when i push the top calipar the bottom one come out is there anyway to prevent that from heppening[/quote:63b952ef2b]
Good luck[/quote:63b952ef2b]
I tried doing that but it wont go in[/quote:63b952ef2b]
Caliper off make sure hose not kinked place an old pad in front the caliper pistons
Using a C clamp
Turn the c clamp handle pushing in the pistons
Or u can push in one side and hold it in using a Vise Grip Pliers
and push in the other one
Oct 10, 2007 at 12:04 PM
GAMEOVER865
[quote:a3566342da="BMRFIXIT"][quote:a3566342da="gameover865"][quote:a3566342da="BMRFIXIT"][quote:a3566342da="gameover865"]on my ford windstar 1999 3.8 LX i tried to replace the front brake pads when i tried to push the calipers one goes in and the other one comes out so for example when i push the top calipar the bottom one come out is there anyway to prevent that from heppening[/quote:a3566342da]
Good luck[/quote:a3566342da]
I tried doing that but it wont go in[/quote:a3566342da]
Using a C clamp
and push in the other one[/quote:a3566342da]
it wont go in is there something that will let the air out
Oct 11, 2007 at 1:35 AM
BMRFIXIT
  • 19,053 POSTS
[quote:f25c1ec88f="gameover865"][quote:f25c1ec88f="BMRFIXIT"][quote:f25c1ec88f="gameover865"][quote:f25c1ec88f="BMRFIXIT"][quote:f25c1ec88f="gameover865"]on my ford windstar 1999 3.8 LX i tried to replace the front brake pads when i tried to push the calipers one goes in and the other one comes out so for example when i push the top calipar the bottom one come out is there anyway to prevent that from heppening[/quote:f25c1ec88f]
Good luck[/quote:f25c1ec88f]
I tried doing that but it wont go in[/quote:f25c1ec88f]
Using a C clamp
and push in the other one[/quote:f25c1ec88f]
it wont go in is there something that will let the air out[/quote:f25c1ec88f]
frozen caliper change it
Oct 11, 2007 at 5:30 AM
