Air/Heat Airflow Direction Control Problem
TSTACK
Ford Windstar, 2002, 70K miles, 3.8L.
Now that we are back in the heating season, I found today that no matter what setting I place the control on, all the air comes out of the top face level vents only. If I select foot level, no change...defrost, no change. I'm guessing that a vacuum controlled airflow direction panel is stuck. I need to know what components to look at or if I will need to do some disassembly to get at it. Oh yeah, I tried the non-tech approach of whacking and banging in some places hoping to jar it loose, but no luck.
Oct 24, 2007 at 4:22 AM
BMRFIXIT
  • 19,053 POSTS
[quote:2e6ae6aac9="tstack"]Ford Windstar, 2002, 70K miles, 3.8L.
Now that we are back in the heating season, I found today that no matter what setting I place the control on, all the air comes out of the top face level vents only. If I select foot level, no change...defrost, no change. I'm guessing that a vacuum controlled airflow direction panel is stuck. I need to know what components to look at or if I will need to do some disassembly to get at it. Oh yeah, I tried the non-tech approach of whacking and banging in some places hoping to jar it loose, but no luck.[/quote:2e6ae6aac9]
how about under the hood
did u check for a vaccum leak or a disconnected hose
around the brake booster and /or firewall area
good luck
let us know
Oct 24, 2007 at 5:23 AM
TSTACK
Ford Windstar, 2002, 70K, 3.8L.
Update from last post reply. I checked firewall area for vacuum hose/leak issues - nothing obvious - all looks normal.
I played around with heat control again - turned control to floor position setting --- after whacking around on the top of the dash a while, I had heat coming for a few minutes mostly from the floor vent with some still at the panel vents. Then tried other positions (like defrost) - wound up with airflow back at the panel vents only. It's schizophrenic.....
Oct 26, 2007 at 10:23 AM
BMRFIXIT
  • 19,053 POSTS
[quote:43c4b99128="tstack"]Ford Windstar, 2002, 70K, 3.8L.
I played around with heat control again - turned control to floor position setting --- after whacking around on the top of the dash a while, I had heat coming for a few minutes mostly from the floor vent with some still at the panel vents. Then tried other positions (like defrost) - wound up with airflow back at the panel vents only. It's schizophrenic.....[/quote:43c4b99128]Know you have heat?
But you can t control the vents
If u look down to the side by the gas paddle under the dash
U see black box on the side of it links are any of it disconnected
Try to change the position of the control while watching the area for any movement
Oct 26, 2007 at 1:07 PM
