Ford Windstar AC Foul Odor
I know they make odor neutralizers to be sprayed in the inlet that may cancel the odor.
Good luck
Suggested Repair
Check that the evaporator drain hoses are clear, connected, and dripping water under the vehicle when the A/C runs. Inspect or replace the pad in front of the evaporator, and treat mildew on the evaporator core with an odor neutralizer or disinfectant spray, possibly after removing the blower motor. A dealer can confirm the Windstar procedure.
Conversation Summary
The owner of a Ford Windstar reported a foul odor when the air conditioning was first turned on. Experts said a clogged evaporator drain can trap water and cause mold, and that mildew on the evaporator core or a dirty filter pad is a common cause. They recommended confirming the drain hoses are clear and dripping, then using a disinfectant or odor neutralizer, and contacting a dealer for the exact spray procedure.
