keypad entry code
2003 FORD WINDSTAR
DOTHCAR
  • 5 POSTS
Would anyone know, where to find the 5 digit code for the door keypad (keyless entry) on 2003 ford windstar ? the owner manual said it stick on the computer module, but where is the computer module ? does anybody know ?help would be very appreciated, Thanks, :lol:
Aug 18, 2007 at 3:14 PM
MIKE H R
  • 3,094 POSTS
The module is on the drivers side, under the dash towards the left, mounted on the inside firewall. But if it is not there you will need to call the dealer with the vin number and they will look it up for you. You will need to prove the car is yours though first.
Aug 19, 2007 at 3:24 AM
DOTHCAR
  • 5 POSTS
Thanks for reply. I found the module but the 5 digit code sticker was not there, any where else i should look ? :(
Aug 19, 2007 at 11:36 AM
MIKE H R
  • 3,094 POSTS
It could be on the back side, Other than that I do not know where it would be. If it is not then I would get in touch with a dealer for ford and see if they had any suggestions.
Aug 20, 2007 at 3:59 AM
DEBBIE JACKSON
How do I reset anti theft module
Aug 17, 2017 at 11:08 AM
  • 55,412 POSTS
If the security light is flashing and you have the correct key remove the negative battery cable for 30 mins and then reconnect, unlock the drivers door using the key or remote and the system should reset.
Here is a guidw that can help as well.
https://www.2carpros.com/articles/how-to-reset-a-security-system
Cheers, Ken
Aug 18, 2017 at 6:44 AM
TTGMUGGLE
hello we just purch. a 2001 winstar and the dealer couldnt tell us the code to unlock the doors or how to reset the code i was wondering if this was an easy job that i could do of if i needed to take it to an actual ford dealer thank you for your help
Jun 26, 2020 at 3:58 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
KEYLESS ENTRY KEYPAD
Enter 5-digit permanent factory entry code into keypad. This code can be found on owner's wallet card in glove box, or taped to Remote Keyless Entry (RKE) module. Within 5 seconds of pressing last button of permanent factory entry code, press 1/2 button on keypad. Holding 1/2 button for more than 2 seconds will erase customer code. Doors will lock and unlock to confirm code has been erased. Within 5 seconds of holding 1/2 button, enter a new 5-digit customer code into keyless entry keypad. Doors will lock and unlock to confirm programming has been successful
TTGMUGGLE
thanks but you see thats still the problem we got the car used (Duh) and the last owner didnt leave the card in the van and the used car dealer didnt know the code nor do they know how to reset it thats what im asking please dont think i have the numbers that make it work if i did i dont think i would be asking if there was a reset not a reprogram
thank you
BMRFIXIT
  • 19,053 POSTS
if u read in the 1st posting I did
((or taped to Remote Keyless Entry (RKE) module)).
it tells u where is the # s that u need
its located at the module in front under the dash
it has a sticker on it with the codes
