2003 Ford Windstar Front Wheel Bearing and Hub
DERF9_9
Suspension problem
2003 Ford Windstar V6 Front Wheel Drive Automatic 39000 miles
My Windstar has noise that increases as I speed up but which sounds like a wheel bearing. When turn hard right the noise increases hard left has no effect so I feel it's the wheel hub bearing assembly which I feel is premature for 39K miles vehicle. I plan on doing the work myself but when I reviewed the shop manual it states to replace the axle shaft nut as well as the 3 bolts that retain the hub assembly and the ball joint nut and tie rod serated nut. I understand why I would change the axle nut but are the other hardware parts really necessary or can I reuse them and just use new cotter pins? I plan on approaching the dealer first to see if they would do the work on a goodwill warranty.
Dec 4, 2007 at 5:42 AM
MERLIN2021
  • 17,250 POSTS
Good luck on the goodwill thing....If they are castle nuts with cotter pins, yes they are reusable, most are locknuts, with plastec inserts, not reusable...
Dec 4, 2007 at 7:24 AM
