ALARM RESET?
KATHY4SYNTY
No start problem -fixed!
Solved the problem of my 2005 Ford Freestar motor not turning over with no apparent cause. Among other possible causes, my anti-theft system locked my motor up (or prevented my starter from engaging the motor) after my battery ran dead and had to be replaced.
The FIX is THIS - make sure the hood is closed (incase it has a sensor), close all the doors, lock the doors with the remote lock, and then start the car with the remote starter. The 1st time it tried to turn over and start but couldn't and made a loud noise. That worried me. But after that, it tried to start again (on it's own, I didn't push the remote start again) no loud noise that time, but still couldn't start when turning over. It tried on its own to start a 3rd time and stared right up, no problem. I unlocked the driver door with the key (not remote), put key in ignition and turned to on, engaged the brake to disconnect the remote, turned the van off, then started it back up with the key in the ignition and it started right up again with no problem. Working just fine since.
I hope this works for someone else who has this problem. This was the 2nd time for me AFTER I ended up replacing the motor the 1st time. So pissed that Ford cost me that money and inconvenience. This anti-theft system is seriously flawed.
Friday, June 19th, 2020 AT 12:45 PM (Merged)
KEN L
  • MASTER CERTIFIED MECHANIC
  • 48,363 POSTS
Great addition to this thread! Please feel free to help out whenever you are on the site :) I would check the battery connecting because it sounds like they are dirty/loose. Here is a guide that can help.
Cheers, Ken
DAVEHAPPYROCK
  • 2001 FORD WINDSTAR
  • 4 CYL
  • FWD
  • 133,000 MILES
I drilled out my ignition and now it won't start how can I locate the anti theft devices wiring so I can cut it
ALEX_BUENA
  • 28 POSTS
I'm confused on why you would drill out your ignition costing you more money instead of getting a replacement key?
