2002 Ford Windstar Power Steering
TRAFFORD
  • 2002 FORD WINDSTAR
  • 6 CYL
  • 48,500 MILES
When the engine heats up, not when the engines cold, and when I make hard turns I can hear the power steering pump really make a louder than usual noise. The fluid level is fine, and the vehicle is okay to drive. I'm wondering if I have to change the pump. Like I said it's only noisy when the engine has been running for awhile.
Monday, July 28th, 2008 AT 8:13 PM
CBPPRUSTY
Hi. This might sound crazy but it worked for me. My P/S Pump on my 2002 Windstar was very loud. Before I replacing it I decided to drain the old fluid, flush with synthetic P/S fluid and then refill with syn. Fluid. Now it's quiet as a mouse. Good luck.
Monday, August 18th, 2008 AT 1:43 PM
RAINESRW4220
FYI - I had the same problem. I thought the pump needed to be replaced too. My Mechanic flushed the power steering system and replaced the PS fluid with synthetic. No more noise!
Monday, November 24th, 2008 AT 9:14 AM
