2002 Ford Windstar Multiple Electrical Problems
2002 FORD WINDSTAR
113,000 MILES • 6 CYL • 2WD • AUTOMATIC
ANIBAL96
I have a ford Windstar 2002. It has multiple problems, first the gas gauge mark like the gas tank is empty, them I have problems with the doors locks only works the driver door. And no tail lights these problems start at the same time. I took the car to mechanic shop but they could not fixed it, only they replaced the gas level sensor, they could not detected the others problems because they showed when the car has been running for 20 or 30 minutes. I check the fuses but I was unable to find anything.
Jul 19, 2009 at 2:23 AM
DOCFIXIT
  • 18,828 POSTS
Hi
need to clearify problem was gas gague repaired ie. is it working? You mean you drive the van 20-30 mins then door locks and tail lights quit?
Let me know
Thanks for donate
Jul 20, 2009 at 3:43 AM
ANIBAL96
A new gas level sensor was replaced on the car. I drove the car from the mechanic shop to home and the doors do not work, just the driver side open. And no tail lights, (no signed lights, no break lights, no reverse lights, and no night lights). The gas gauge sometimes marks a full tank, empty, or half full. This occurred every time the motor is stared. Ignition light is on all time.
Jul 20, 2009 at 4:28 AM
DOCFIXIT
  • 18,828 POSTS
Belive your problem is Rear Electronic Module all the things that are not working are controlled by this module. Located behind right rear quarter panel.
Jul 20, 2009 at 7:28 AM
