2002 FORD WINDSTAR AC/HEATER NOISE
TINAMARIE161
I have a 2002 Ford Windstar,120K miles, V6 - when I attempt to turn on the a/c or adjust any of the switches the unit starts making this knocking noise; if I try to use the heat I get the same knocking noise plus the smell of burning rubber. Noticed today that the knocking noise is now constant -- no switches were touched or adjusted. What is the problem?
Aug 7, 2007 at 10:39 AM
CARNOV123
I had the same problem. there is a little motor in the dash that changes the air flow. Ours would just tick tick tick away. Think it was a couple hundred bucks to fix
Nov 28, 2007 at 10:44 AM
