2002 Ford Windstar heater wont blow warm air
ROBERT GRAHAM
Heater problem
2002 Ford Windstar V6 Front Wheel Drive Automatic 60000 miles
the heater blows cold air all the time,even when the engine is been warmed up.checked for any leaks on passenger floor and found none,also checked coolant level and it is fine
Dec 2, 2007 at 10:13 PM
2CARPRO JACK
  • 11,533 POSTS
Look inline on the heater hoses for a heater control valve. Be sure that when you select hot, it is letting the hot water in.If it doesnt have one, then check the blend door under the dash to be sure it is moving to hot position
Dec 3, 2007 at 8:16 AM
