2001 Ford Windstar Windstar has no 12v from switch to the s
123,000 MILES • 6 CYL • 2WD • AUTOMATIC
JODIDANESE
Van would not start last week. This is what we have done so far... battery was drained so new fully charged battery was put in. Alternator was replaced, old one was bad. Replaced the ignition switch and we took out the radio because I thought it may be contributing to the drained battery since CDs were stuck in the changer. (wasn't sure if that had anything to do with current prob but am planning on replacing anyway, so went ahead and removed it). We replaced all the battery cables and clamps. There is no current from ignition switch to starter solenoid small terminal.
Oct 24, 2010 at 1:23 PM
  • 75,988 POSTS
Hi jodidanese, Welcome to 2carpros and TY for the donation
You've replaced the ignition switch-check fuse no.105 30amp in the battery junction box left side of engine compartment if okay-now you check and test the starter relay and the transmission range switch its between this two where the problem lies if not its an open wire between the starter motor and ignition switch
Oct 24, 2010 at 2:01 PM
