Key stuck in the ignition
80,230 MILES • 6 CYL • FWD • AUTOMATIC
NSISMYJOB
Key will not turn in the ignition. Anti thief light flashing.
Jun 15, 2010 at 11:21 AM
SQM
  • 6,383 POSTS
Take a look at this article. This might help you through the process:
https://www.2carpros.com/articles/ignition-switch-wont-turn-stuck
Let me know if you have any questions.
Jul 16, 2021 at 1:04 AM
More then likely this is an issue with the interlock solenoid. However, here is a guide that will help with this issue in more general terms:
Below you will find the process for the solenoid which is what I suspect will have to be replaced.
The theft light is blinking most likely because the ignition is not turning. It is normal for it to flash slowly while the key is off.
Please run through this info and let us know if you have other questions. Thanks
Jul 16, 2021 at 1:19 AM
