2001 Ford Windstar heater not working
86,000 MILES • 6 CYL • FWD • AUTOMATIC
JAADKINS
On my 2001 ford Windstar, the heater is not blowing warm air all the time. Iwas told it could be the thermostat, i checked the coolant resivoir, it was close to empty, so i filled it with water, the heater began to work right again. That was 5 days ago, this morning it did not want to heat up at all. I checked the resivoir and it is almost empty again. Would changing the thermostat fix this problem and why is the resivoir empty. There are no puddle's under the car where if could be leaking, and it is not running hot either.
Oct 9, 2008 at 12:39 AM
OBXAUTOMEDIC
  • 3,719 POSTS
[quote:4cf99375b3="jaadkins"]Heater problem
2001 Ford Windstar 6 cyl Front Wheel Drive Automatic 86000 miles
On my 2001 ford Windstar, the heater is not blowing warm air all the time. Iwas told it could be the thermostat, i checked the coolant resivoir, it was close to empty, so i filled it with water, the heater began to work right again. That was 5 days ago, this morning it did not want to heat up at all. I checked the resivoir and it is almost empty again. Would changing the thermostat fix this problem and why is the resivoir empty. There are no puddle's under the car where if could be leaking, and it is not running hot either.[/quote:4cf99375b3]
Have you noticed a Sweet smell inside the vehicle?
Check the floor on the passenger side, is it wet. If so most likely you have a leak heater core...
Dec 20, 2016 at 10:17 AM
