no heat
170,000 MILES
RUFUSRICH2779
  • 9 POSTS
My heat doesn't work i changed blend door actuator and flushed out heater core. Van runs at normal temperature and radiator hoses get hot so i don't think its thermostat. I manually moved blend door and no heat still came out. My coolant is rusty looking could that have something to do with it. Air blows cold in back also.
Feb 9, 2016 at 5:11 AM
WRENCHTECH
  • 20,758 POSTS
Are both heater hoses at the firewall hot to the touch?
Dec 20, 2016 at 10:08 AM
RUFUSRICH2779
  • 9 POSTS
The inlet hose is and the outlet is cold
WRENCHTECH
  • 20,758 POSTS
Then you have a restricted heater core and it needs to be replaced.
RUFUSRICH2779
  • 9 POSTS
when i took heater core hoses off no coolant came out of heater or hoses could something be stopping coolant flow from getting to heater
WRENCHTECH
  • 20,758 POSTS
Yes, a bad heater core.
RUFUSRICH2779
  • 9 POSTS
Changed heater core blend door actuator still no heat. Van at normal running temp. Coolant a little rusty
WRENCHTECH
  • 20,758 POSTS
And why would you change a blend door actuator when I advised you that you had a restricted heater core?
RUFUSRICH2779
  • 9 POSTS
Heater hoses barely warm. I left left coolant top off while van was running and coolant started coming out. I changed actuator because it was knocking and teeth on gear had broken off
  • 55,816 POSTS
Does that model have a heater control valve?
WRENCHTECH
  • 20,758 POSTS
No, it does not. Those 2 heater hoses are connected directly to the heater core.
RUFUSRICH2779
  • 9 POSTS
What could be blocking coolant from reaching heater core could water pump be malfunctioning
WRENCHTECH
  • 20,758 POSTS
There was no mention of the car overheating so no, I don't believe that is possible.
RUFUSRICH2779
  • 9 POSTS
What could be restricting coolant from flowing to heater core
WRENCHTECH
  • 20,758 POSTS
I've already answered that question twice. You need a heater core.
RUFUSRICH2779
  • 9 POSTS
I have replaced heater core
WRENCHTECH
  • 20,758 POSTS
With new or used?
There is nothing else that can restrict it unless your hoses are kinked. If the water pump wasn't working properly the car would be overheating.
RUFUSRICH2779
  • 9 POSTS
Its new
  • 55,816 POSTS
We have had other members tell us that air bubbles can get trapped in the heater core by jacking up the rear of the car or the front of the car it can help burp the system here is more information for you, please get back to us on what you find so it can help others
https://www.2carpros.com/articles/car-heater-not-working
WRENCHTECH
  • 20,758 POSTS
Most of us fill by vacuum now and that eliminates all air in the system.
