thanks,april
2001 Ford Taurus AC Compressor Seized
thanks,april
Suggested Repair
Replace the seized AC compressor first so the drive belt can be restored and the charging, oil-pressure, steering, and starting symptoms can be addressed. For no heat, compare the heater hoses at the firewall at normal temperature; if both are not hot, flush the heater core, but replacement is more likely.
Conversation Summary
The owner of a 2001 Ford Taurus reported a seized AC compressor, a broken belt, hard starting, tight steering, warning lights, a long-standing sweet smell, and no heat after cooling-system repairs. The expert said the broken belt explains those running symptoms and recommended replacing the compressor first, including because it engages in defrost. For the heat problem, both heater hoses should be hot at normal temperature; otherwise flush the heater core, though replacement is more likely.
