2000 Ford Windstar O/D light worry
91,500 MILES • 6 CYL • 2WD • AUTOMATIC
CIERDWYN2
I have a 2000 Ford Winstar with 91,500 miles on it. The other day I go in the car and turned it on and automatically all the doors locked. this usually doesn't happen until i start driving. Just as I started to back out of my space, I noticed that the O/D light was blinking. I pressed the button for it a couple times, thinking I had bumped it, but nothing happened. When I put the car in gear, the light immediately stopped blinking.
I've had the car on 4 times since then. The light blinks when it's in park, but when I put it in Reverse or Drive, the light stops blinking. There is no fluid leak,and I have plenty of fluid(I thought this might be the initial problem, and I was a little low, so i added some.)
Dec 17, 2007 at 1:50 AM
2CARPRO JACK
  • 11,533 POSTS
That is the PCM telling you there is a problem with the trans or the system controlling it. Have the PCM scanned for codes and get back with the results
Dec 17, 2007 at 11:43 PM
CIERDWYN2
Ok, this may seem naive of me, and for that I apologize. Cars are a thing I've only been involved with for the last 3 years due to eye problems,so I'm out of my depth. When you say get it scanned, are we talking taing it to a shop, or is there something I can do myself?
Dec 17, 2007 at 11:55 PM
2CARPRO JACK
  • 11,533 POSTS
Sorry, my bad. Scanning it means having the PCM (Powertrain Control Module) scanned for trouble codes.When your cars computer sees a repeated failure in a system it will store a code, or reference to the system that is having a problem. Autozone will scan it for free, or you can buy your own code reader for fairly cheap.
Dec 18, 2007 at 3:48 AM
