2000 Ford Taraus SES
VOLATTIC
  • 8 POSTS
I have a 2000 Ford Taraus with 95,000 Miles on it.When i start driving it and it shift's gears it seems like it Stutters a bit but after i push the Gas it seems to be fine.It does this somtime when changing Gears.What would be the Proper steps to take.Thanks
Apr 8, 2007 at 10:17 AM
  • 75,988 POSTS
[quote:d00743b2a5="volattic"]I have a 2000 Ford Taraus with 95,000 Miles on it.When i start driving it and it shift's gears it seems like it Stutters a bit but after i push the Gas it seems to be fine.It does this somtime when changing Gears.What would be the Proper steps to take.Thanks[/quote:d00743b2a5]
Last transmission service?
Apr 8, 2007 at 11:41 AM
VOLATTIC
  • 8 POSTS
any info on this rhanx
Apr 9, 2007 at 4:25 AM
  • 75,988 POSTS
[quote:2dbfc46f28="volattic"]any info on this rhanx[/quote:2dbfc46f28]
Try changing the tranny's fluid and filter-the OBD2 panic lite/SES/CEL is it On or flashes at times.
Apr 9, 2007 at 8:32 AM
VOLATTIC
  • 8 POSTS
Ok thansk for the help.Do you think it could be going out on me.
Apr 9, 2007 at 9:45 AM
  • 75,988 POSTS
[quote:123f2c45a8="volattic"]Ok thansk for the help.Do you think it could be going out on me.[/quote:123f2c45a8]
Well, when is the last time you have it serviced, if not sure when-get it done and comeback and we'll look into other areas that can be causing it.
Apr 9, 2007 at 1:37 PM
