seems to be better when car has been running for awhile sometimes has difficulty switching gears if that makes sense sometimes its fine
transmission fluid has not been changed since ive had the car nor the filter , fluid was little low when checked it and added some.
what could be going wrong with the transmission?
does this sound like a simple issue or do I need a new transmission?
engine light is on, cam shaft sensor and another simular sensor
but ive been told has nothing to do with transmission is that true?
I will be getting the sensors replaced soon want to hit the bigger problems first
