1998 Ford Taurus engine swap possibilities
DEREK1971
Transmission problem
1998 Ford Taurus V8 Front Wheel Drive Automatic
im thinking of swapping a sho v8 into my bronco 2....is there a rear wheel drive transmission that will bolt up to it
Oct 8, 2009 at 4:04 PM
BMRFIXIT
  • 19,053 POSTS
Assuming that engine fit in and mounted
and you found a tranny too
may I ask how is it your going to fire it and run it
its a very big project that require a lot of manufacturing
Oct 9, 2009 at 11:58 PM
DEREK1971
getting the engine to fire and run can be done by using the wiring harness and computer out of the donor car i know the engine will need to be connected to the trans.but the computer can be programmed to be compatible with the new one.... where theres a will theres a way
Oct 10, 2009 at 7:47 AM
