1999 Ford Windstar KEY WON'T TURN
1999 FORD WINDSTAR
106,000 MILES • 6 CYL • FWD • AUTOMATIC
M43RF
THE KEY WON'T TURN IN THE IGNITION EVEN AFTER TURNING THE WHEEL BACK AND FORTH. IT SEEMS THAT THERE IS A LOT OF PRESSURE IN THE POWER STEERING SYSTEM ?
Jun 29, 2009 at 5:52 AM
BLUELIGHTNIN6
  • 16,542 POSTS
You should check out our "First Things to Check" page. It has a lot of good information about this common fault. You can visit the page by following the link below..
https://www.2carpros.com/first_things/why_wont_my_ignition_switch_turn.htm
Jun 29, 2009 at 5:56 AM
