White smoke coming out of the tailpipe is a bad sign. You may have a blown head gasket. Idle the car a while from a cold start, then while in Park, accellerate the engine a bit. If lots of water drains from the tailpipe and if it smells a bit like bad fish, it is coolant. Eg blown head gasket.
Second test: From a cold start, remove radiator cap temporarily and run the engine for a few seconds. While running, install radiator cap and then remove again. If there is lots of pressure built up inside radiator, exhaust gas is pushing its way thru the (broken) head gasket and into the cooling system. The only remedy is to replace the head gaskets.
More importantly is to make sure the radiator is filled to capacity. The plastic overflow resovoir is just a secondary holding tank. But if the radiator is empty and the resovoir is full, the engine will overheat regardless.
Windstar/Taurus engines are very sensitive to overheating. Blown head gaskets are a common result.
SPONSORED LINKS
Thursday, February 19th, 2009 AT 10:08 PM
