If your van needs a tune up would your check engine light go on?
Thursday, January 1st, 2009 AT 10:07 AM
DAVE H
MECHANIC
The CEL comes on when the PCM detects a fault in the system. Ie. Misfire/fuel lean/rich. It does not tell you that your engine needs a tune up. Although in some cases a tune up can cure the fault detected.
