1998 Ford Windstar thrown rod
51,481 MILES • 6 CYL • FWD • AUTOMATIC
LAURALW
I had work done on van. o2 sensor,air filter,egr block to manifold gasket, intake manifold gasket,tune up with oil change, and antifreeze flushed and filled. Also had an inspection. They also drove it about 30 miles to reset the engine light. 1 week and about 100 miles later driving along at about 30 mph I threw a rod. It went through the oil pan. Lost almost all oil and there is no antifreeze left in the radiator. Could work they did have caused this or is it just a coincidence? Any advice you could give would be greatly appreciated. Thank you
Jan 5, 2009 at 5:18 AM
  • 110,248 POSTS
Based on the list of work completed, there really isn't anything they did to cause this. However, if there was no coolant in the engine, that may have led to the problem. Did the temp gauge ever read hot?
Jan 13, 2009 at 7:40 AM
LAURALW
The van was actually running great and was not reading hot. It just made a big bang noise and stopped running.
Jan 13, 2009 at 8:31 AM
  • 110,248 POSTS
Hi:
That is how it usually happens. But, the "no coolant" has me confused. By any chance does it look like there was coolant in the oil?
Jan 13, 2009 at 1:45 PM
