1998 Ford Windstar Hard to start van when engine is hot
1998 FORD WINDSTAR
ISLANDER13
1998 Ford Windstar 6 cyl Front Wheel Drive Automatic 182 K miles
When van is first started (first x of day, or after engine has cooled), it starts right up. After van has been driven and engine is hot - van does not like to restart. It chugs, and sputters and dies. Have to wiat for engine to cool or give car lots of gas while foot on brake and van in gear.
Aug 9, 2009 at 1:27 PM
SCHRIMPIEMAN
  • CAR REPAIR CONTRIBUTOR
  • 166 POSTS
Check the coolant sensor; it may have failed, making the car computer think it is constantly cold: enriching the fuel mixture.
A rich mixture is fine for cold start-ups, but when the engine gets warm, the air/fuel mixture needs to lean out. Without proper input from the coolant temp sensor, the mixture will stay rich, causing running trouble as you describe.
There's two sensors... one for the gauge needle, and one for the PCM.
Focus on the sensor with two wires: Should be LightGreen-RedStripe and Grey/RedStripe.
The other one with only one wire (Red/WhiteStripe) is for the instrument panel gauge.
Both sensors are next to each other near the throttle body on the intake plenum. Pull off the air intake snorkel and you should be able to see them.
Aug 21, 2009 at 6:44 PM
