Took it to VIP to get it inspected.. here are the codes they got..p0455,evap leak, p0430,cat bank 2 p0302,#2 misfire, p0171,system 2 lean bank, and p1537 & p1538, these codes make sense, except the last two.. they have it down as Idle speed, when everywhere else, including you guys, has it as an intake manifold issue.. are the two connected somehow? I just need to know if I should be looking at the manifold or the idle, or both?? bit confusing as I've never owned a Ford van. How many of these codes coincide with each other? I.E. p0430 & p0302 & p0171???
Thanks for any info you may be able to give me!
Mar 19, 2009 at 11:32 PM
