1998 Ford Windstar
BLUEBEAR
  • 1998 FORD WINDSTAR
Engine Performance problem
1998 Ford Windstar 6 cyl Front Wheel Drive Automatic
when I get on the gas it is sluggesh and feels like it has cugging when you go down the road?
Wednesday, December 31st, 2008 AT 7:53 AM
SCHRIMPIEMAN
  • 166 POSTS
If it idles seemingly well, but doesn't have any power, try replacing the fuel filter. The engine may be starving for fuel.
Or, you may have an exhaust restriction. Remove the upstream oxygen sensor (sensor nearest the engine block) and drive the car for a bit; see if there is any noticible difference (despite the roar of noise).
Realize you'll likely get a check engine light for temporarily removing the O2 sensor, but it's all part of diagnostics. Have a code reader handy to clear codes.
Tuesday, February 10th, 2009 AT 7:59 PM
