1996 Ford Windstar Service Engine Trouble Light
JOHNANDJJ
  • 1996 FORD WINDSTAR
  • 6 CYL
  • FWD
  • 103,000 MILES
My '96 Windstar was hard starting and ran very rough (stalling till I floored the gas). The "service engine" light immediately came one. I took the car to an auto store, had a diagnostics run which showed the code "Cylinders 4 & 5 mis-fire". Starting at the basics, we changed the plugs and wires but the problem re-occurred afterwards.
What next?
Tuesday, March 10th, 2009 AT 4:24 AM
BMRFIXIT
  • 19,053 POSTS
Still have the same codes?
Check if coil firing the two cylinders
if so
do a compression test
if OK check injectors
bad coil is more common
Tuesday, March 10th, 2009 AT 6:02 AM
JOHNANDJJ
  • 5 POSTS
The book identifies the coils for cylinders other than 4 & 5 (i.E. - Coil #1 services 1&5, coil #2 services 2 & 4, coil #3 services 3&6- I may have these wrong but there is no single coil that services 4 & 5. When we did the plugs, we saw that the egr ports were filthy. Could this be the issue?
Thursday, March 12th, 2009 AT 10:43 AM
BMRFIXIT
  • 19,053 POSTS
If the EGR stuck open I would expect to see misfiring codes and other codes too
related ti that issue
but if its clogged and close no will not effect it
check the firing order making sure did not crose any wires
pull the wire of the coil and check if its arcking out and strong
coils is a common failure too
let me know
PS do u need the firing order?
Let me know
Thursday, March 12th, 2009 AT 1:27 PM
JOHNANDJJ
  • 5 POSTS
My son took of the manifold (?) To get access to the egr ports and cleaned them thoroughly with carb cleaner and compressed air. He last reported that the van was running fine. He cleared the trouble codes with the OBD and the trouble code did not recur. So I think that we got it.
Thursday, March 12th, 2009 AT 2:06 PM
BMRFIXIT
  • 19,053 POSTS
Very possible it was the manifold gasket !
Too
happy for you all OK
will be here if you need any more info
just let me know
thank you
Thursday, March 12th, 2009 AT 5:14 PM
