1996 Ford Windstar no front heat
THEJBOYDS
Heater problem
1996 Ford Windstar 130000 miles
Rear heat works fine cold air blows out of top(defroster) and out of reg vents when heat is on.was toldto flush lines.not sure what they mean how do you flush them with air or water?do you think this will work or might it be something else.doesnt make any noises.
Jan 21, 2008 at 12:11 PM
BMRFIXIT
  • 19,053 POSTS
[quote:53310b2a5c="thejboyds"]Heater problem
Rear heat works fine cold air blows out of top(defroster) and out of reg vents when heat is on.was toldto flush lines.not sure what they mean how do you flush them with air or water?do you think this will work or might it be something else.doesnt make any noises.[/quote:53310b2a5c]
u can do that but check the blend door actuator
its job to close door and open between the hot and cool air
Dec 20, 2016 at 10:22 AM
