1996 Ford Windstar Ignition/ Park switch problem
LAUGHINGCLOWNJACK
  • 1996 FORD WINDSTAR
#%*%&$ Car won't Start!
Thanks for the tip about the 2 bolts on the steering column shifter. (91 tourus wouldn't go into park)
My Windstar has a simular problem. It goes into park but won't start, to start it I've had to pull the shifter up and back to the "magic spot" to get it to start and the other day it didn't work at all.
After reading your reply to the Tourus I checked and found the loose bolts.
I just tightened them finger tight (on lunch hour) but still no luck.
My question, Is there anything else I should look for if this doesn't work?
Monday, May 21st, 2007 AT 12:20 PM
LAUGHINGCLOWNJACK
  • 6 POSTS
Well, still no go.
My theory is that I have broken the "switch" that is activated when the shifter is in the park postion by pulling on it over and over when I started it.
Does this sound pausible?
Tuesday, May 22nd, 2007 AT 4:06 PM
LAUGHINGCLOWNJACK
  • 6 POSTS
Backup lights work.
Doesn't start in nuetral, I don't think it ever did.
NEXT
Tuesday, May 22nd, 2007 AT 5:52 PM
LAUGHINGCLOWNJACK
  • 6 POSTS
Thanks for your help.
It turned out to be the Solanoid
It's back on the road and better than it was before.
This website is great.
I'll be back.
Thanks again
Wednesday, May 23rd, 2007 AT 8:12 AM
