1996 Ford Windstar battery saver relay
1996 FORD WINDSTAR
195,231 MILES • 6 CYL • FWD • AUTOMATIC
ARMYMAN11602001
on my windstar i have replaced the battery saver relay once already and 2 days later it is acting up with the relay in the van wont start no lights no nothing i am unsure of what to do any help would be greatful
Feb 24, 2009 at 6:45 PM
SCHRIMPIEMAN
  • 166 POSTS
Are battery contacts clean and tight? Take terminals off the battery, clean them well and see if this makes a difference. They may look clean from the outside, but it's the contact they make to the battery posts which make all the difference.
If yes, I believe there is a "Main Relay" which provides power to most functions in the electrical circuits. If this Main Relay is bad, it can result in a dead car as you describe.
Feb 27, 2009 at 10:02 PM
SCHRIMPIEMAN
  • 166 POSTS
I just checked my Hayne's repair manual wiring diagram after I submitted the first reply.
There is a PCM Power Relay..... Location is in the engine compartment fuse box.
Ford provides owner's manuals online by going to www.motorcraft.com and clicking on the "Technical Resources" link. Download your owner's manual if you don't have it. The picture and location of the relay will be in the "Roadside Emergencies" section.
Feb 27, 2009 at 10:11 PM
