HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Windstar
Ignition
Coil
Replace/Remove
SPONSORED LINKS
1996 Ford Windstar
JONSHELA
MEMBER
1996 FORD WINDSTAR
Engine Performance problem
1996 Ford Windstar 6 cyl Two Wheel Drive
p0302 code set. I have replaced coils, wires, plugs? I'm not sure how the ecu monitors each cylinder, so i'm not sure which way to go.
Sunday, September 19th, 2010 AT 10:16 AM
MERLIN2021
MECHANIC
Check the injector for firing, use a noid light (available at all parts stores), and compression check the engine.
SPONSORED LINKS
Sunday, September 19th, 2010 AT 10:19 AM
JONSHELA
MEMBER
I'll give that a try.
Sunday, September 19th, 2010 AT 1:30 PM
MERLIN2021
MECHANIC
Let me know the result.
Sunday, September 19th, 2010 AT 6:45 PM
Please
login
or
register
to post a reply.
Related Ignition Coil Replace/Remove Content
2000 Ford Windstar Ignition Coil Replacement
My 2000 Ford Windstar Sel 3.8l 6 Cyl Minivan Had Smoke Pouring In Through The Dash Board. I Immediately Parked It And Shut Down The Engine....
Asked by
Phill81975
1 ANSWER
2000
FORD WINDSTAR
VIDEO
Instructional repair video
Coil Problem?
Hi, My Father's 1986 Mercury Grand Marquis Will Not Start. He Replaced The Coil Already. Please Understand Over The Phone He Told Me...
Asked by
bigbadbeauvais
FORD WINDSTAR
2002 T-bird
I Have A 2002 T-bird That Has A Bad Vibration And Miss. I Have Had It In The Shop Numerous Times. The Fist 2 Times W/i 2 Weeks Of Each...
Asked by
rainfall
2002
FORD WINDSTAR
2002 Ford Windstar Ignition Coil Replacemet
How To Replace An Ignition Coil On 2002 Ford Windstar
Asked by
dbwade
1 ANSWER
2002
FORD WINDSTAR
1998 Ford Windstar
1998 Ford Windstar I Have A 1998 Ford Windstar 3.0l Engine, And I Needed To Know The Cylinder And Coil Terminal Location. Is There...
Asked by
adling777
1998
FORD WINDSTAR
VIEW MORE
SPONSORED LINKS
Crankshaft Sensor Symptoms
Crankshaft Sensor Replacement
Tune up
Online car repair manuals
