Docfixit,
I am so sorry for the slow reply. Had an emergency in the family.
To better answer your questions, I took a drive in it and found that the tran. Will wind out in 1st and sit at that point for a few seconds before starting to slip. It never does shift into 2nd. I tried to shift into second manually and found that it will go into 2nd only after a few second slip from 1st. 2nd will not wind out all the way before the van starts jerking.
The check engine light is not on. And it does have reverse.
The owner said that he will get it checked for codes but, I wouldn't count on it. I just told him that he needed another transmission. Unless you know of a cheaper solution.
Thanks again for the reply.
Friday, May 29th, 2009 AT 4:55 PM
