1995 Ford Windstar ignition chime/warning bell
120,777 MILES • 6 CYL • 2WD • AUTOMATIC
BLADEM
The van has an electric drain per a scan from a local parts store. The key left in the ignition warning chim will continue to go off after the keys are removed unless you wiggle the ignition switch just right when removing the keys. could the short becoming from the ignition switch?
Apr 16, 2010 at 12:38 AM
  • 110,251 POSTS
Chances are it is the tumbler itself
May 12, 2010 at 6:40 AM
