1995 Ford Windstar battery
156,000 MILES • 6 CYL • FWD • AUTOMATIC
SOPHIE123
I adjusted my Belt today because it was loose. However, when i finish putting the belt back on, i started the vehicle and the battery warning light came on and stayed on. The alternator were making this high pitch noise, and i noticed the belt was loose. Is my alternator bad.
Nov 24, 2008 at 9:40 AM
DAVE H
  • 13,383 POSTS
re-adjust the belt to make it tight ..
BELT TENSION
Inspect condition and tension of generator drive belt prior to performing any on-vehicle charging system tests. Replace belt and/or repair tensioner mechanism if necessary. Belt tension is okay if belt length indicator is within limit marks on tensioner. Replace belt and/or tensioner mechanism if necessary.
Nov 24, 2008 at 10:20 AM
