1989 Honda Accord AC Won't Turn Off
KOKORO
1989 Accord 2lt with 270,000km....I am unable to switch off air con at console! Perfect until a few days ago when air con started working without being turned on. Currently operates as if vehicle has temperate/climate control, but doesn't turn off even when it is freezing! Unable to locate a fuse so it can be disabled until I can afford to have it looked at. Has this occurred to anyone? Any tips for disabling safely? Would sincerely appreciate any help. From Australia and extremely hot here.
Jan 16, 2007 at 8:09 PM
BRUCE HUNT
  • 3,754 POSTS
You can pull the A/C clutch relay out of the fuse box under the hood. I think you will find that the problem you are experiencing is a switch. That means tearing in to the console.
Jan 17, 2007 at 6:04 AM
LOSONE
  • 1,616 POSTS
Again Bruce is correct however that model has an A/C amplifier that is a small black box about the size of a mans wallet. It should be visable if you remove the right side under dash cover. If it is not RH drive you can slip the rubber gromest on the glove box and see it there. Disconnect it and see if the A/C shuts off.
I fixed a Honda with a simiiar problem and that was a bad fan relay with fed the voltage back to the A/C clutch, keeping it on.
Good Luck Losone
Jan 22, 2007 at 9:45 AM
Suggested Repair
Pull the under-hood A/C clutch relay to disable the compressor until it can be repaired. The console switch is a likely cause. Also locate the A/C amplifier under the dash and disconnect it to see if the system shuts off, and check for a fan relay backfeeding voltage to the A/C clutch.
Conversation Summary
The owner of a 1989 Accord cannot switch the air conditioner off, and it runs even when not selected. Experts advise removing the A/C clutch relay, suspect a console switch, and suggest disconnecting the under-dash A/C amplifier. A similar Honda case was traced to a bad fan relay feeding the clutch.
