2001 Ford Truck half my fuse block has no power
2001 FORD TRUCK
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
RCASH
the last 8 of my vin are 1kf49514
I recently replaced a fuel injector on my truck and ever since then my fuse block inside the cab has no power to half the fuses. I also have a trouble code p01289 and p0125 my temp guage dosnt work and the oil light and temp light are also on. the only other thing i can notice is that my a/c wont cycle can you think of where i should start. the last 8 of my vin is1kf49514 thank you in advance Ryan Cash rcash@rocketmail.com
Jan 29, 2009 at 11:02 PM
  • 31,937 POSTS
HI there,
I will need a model identification so i can check the correct wiring schematic for you.as i am in Australia Ford truck can mean quite a few models.
mark (mhpautos)
Jan 30, 2009 at 2:29 AM
