2001 Ford Truck Bank 2 running lean
2001 FORD TRUCK
115,000 MILES • 6 CYL • 2WD • AUTOMATIC
GABBY&3
I need to know what vacuum leaks would cause this and where to find them. A diagram of the vacuum system may help. I had a repair of the intake that was leaking air about seven months ago.
Jan 18, 2010 at 8:49 PM
THEGR8DH
[quote:9ad6103e19="gaBBy&3"]Engine Mechanical problem
2001 Ford Truck 6 cyl Two Wheel Drive Automatic 115000 miles
I need to know what vacuum leaks would cause this and where to find them. A diagram of the vacuum system may help. I had a repair of the intake that was leaking air about seven months ago.[/quote:9ad6103e19] / I'm not sure if you've checked or not but on the back of some Ford engines there is an l shaped hose that comes from the intake to the valve cover that will get a hole over time . you might try checking it
Jan 22, 2010 at 8:48 PM
