Welcome to the forum, if sometimes the starter won't crank, check the circuits at the starter relay. Is it on the fender lining?
One large cable from the battery, the other goes to the starter. A small wire, red with lite blue tracer, comes from ignition switch throught the neutral switch. when trying to crank, that wire should be hot? Have you tried cranking in neutral, when the problem occurs?
SPONSORED LINKS
Tuesday, October 27th, 2009 AT 11:26 AM
