1980 Ford Truck Won't Start
DAN13075
  • 1980 FORD TRUCK
  • 6 CYL
  • MANUAL
  • 160,000 MILES
When I turn the key the dash lights come on and all electricl devices work just fine but when I turn it to the start position nothing happens.
Thursday, November 27th, 2008 AT 3:00 PM
  • 109,885 POSTS
Hi:
Have a helper turn the key to the start position while you check for voltage to the small wire on the starter. If there is power, replace the starter. If there is no power, you will need to have the ignition switch checked.
Friday, December 12th, 2008 AT 1:42 PM
